PlanMaker Lagging Badly
RJDrdul
Post by RJDrdul »
PlanMaker is lagging badly, to the point that I can't use it anymore and am having to work on spreadsheets in LibreOffice Calc instead (gasp!). There is a lag of a second or more when clicking buttons or entering/editing the contents of a cell. I'm running the current version 1504, and as far as I can remember this wasn't a problem with previous versions. I am also on macOS Sequoia 15.8.1 with a M4 Pro MacBook Pro. Any other reports of this problem, and any suggestions as to what it could be?
Maths
Re: PlanMaker Lagging Badly
Post by Maths »
I tested it on Planmaker (Android 9). I checked and found that this issue does not exist. I entered text into the cell and pressed Enter. Everything worked normally. The software runs very smoothly. It seems this bug occurred on your device. I think you should provide a more detailed video to clarify the issue.
I love Softmaker and won’t use any other software
I love the Softmaker file format. I I really like Softmaker software because the software updates always include new features
RJDrdul
Post by RJDrdul »
That’s good to hear that PlanMaker works fine on Android, but this is the PlanMaker for Mac forum and my problem is on a Mac.
Maths
Post by Maths »
You should record a screen video of the issue you're experiencing. It appears that this issue only occurs on your device. Recording a screen video is a good way to report the issue in more detail. This will help Softmaker identify the issue.
lgsl
Post by lgsl »
RJDrdul wrote: Thu Oct 08, 2026 4:21 am That’s good to hear that PlanMaker works fine on Android, but this is the PlanMaker for Mac forum and my problem is on a Mac.
Just ignore the jester.
Are you experiencing the lagging with a particular file or any file? If is with a file in particular I am sure the SM team will want to take a look at it.
Does this file(s) contain simple calculations or incredibly complex ones? Are macros involved?
Return to “PlanMaker for Mac”
