can't activate
can't activate
Dear...
I bought de office 2024. Got the key in the mail. Try to register; computer said "can't connect to the regestration server"
I disabled all antivirus and firewalls. Still no succes.
Try to contact the support, no reaction...
What to do?!
What to do?!
- Contact:
Re: can't activate
Some stupid spammer overloaded one of our servers today. This is solved and will likely not happen the same way in the future.
Please activate now.
Re: can't activate
Thank you for responding,
Sorry, still does not work!
Re: can't activate
We apologize for the inconvenience. Could you please share a screenshot of the activation error so we can better understand the issue?
Re: can't activate
When I enter the number from the email, the response is in the attachment.
Re: can't activate
Thank you for sharing the screenshot. It appears that the issue is related to your network, as there are no problems with our servers.
Please check whether any third-party software is blocking SoftMaker Office from connecting to the activation server.
You may also try starting your system in Safe Mode with Networking to rule out any software interference.
Re: can't activate
Thank you for helping.
I reboot in safe mode with is cable direct to my fritzbox router. Same result.
I disabled all anti virus software and firewalls. Same result.
What port is involved? and wat IP adres, I will try to ping your registration server.
Re: can't activate
Thank you for trying Safe Mode with Networking.
Could you please confirm whether your internet connection is working in Safe Mode? You can test this by opening your operating system's native browser (e.g., Edge or Internet Explorer).
If you have admin access to your router or can contact your ISP, please also check whether a proxy server or router-based firewall is enabled, and try disabling it temporarily for testing.
Re: can't activate
Yes, internet is working on my laptop with window in safe mode and a UTP cable connected to the router.
The router has a firewall, disabling is not possible! I also tried connecting via my phone hotspot. No result.
Please tell me the TCP-IP adres of your registration server and the port this server uses. I will try to ping your server.
Re: can't activate
You can check whether your computer can communicate on the standard TCP/IP ports 80 and 443 (used by web servers).
These ports need to be open for the connection to work properly.
The licensing server's domain is licensing.softmaker.com
Re: can't activate
Thank you, the ping was succesfull. Comunication on port 80 en 443 are open. still no succes.
Re: can't activate
Thank you for sharing the screenshot. Please check your private message Inbox.
