Section & Chapter break problem
I have a master document (template) for a monthly newsletter that was created in Microsoft Word 2016. The format calls for article headlines to span the full (margin) width of the pages, but the body text of each article occupies two columns. In Word, this is accomplished by using a continuous section break (Insert > Break > Section > Continuous) to allow changing from a single column to two columns on the same page.
When the same document is opened in TextMaker 2026, the <Section Break (Continuous)> tag is converted to a Chapter break tag and the two columns of body text are moved to the top of the following page. I attempted to correct for this by replacing the Chapter break with a Section break, and it did not resolve the problem.
Please fix it. Formatting consistency with Microsoft Word documents is essential.
Screen shots attached.
Re: Section & Chapter break problem
Thank you for your report. To check how the continuous section break is converted, I need the Word document in which this happens.
Please attach the DOCX file here and tell me on which page the break is located, and whether it changes when you open the file or only after saving it in TextMaker.
Please also attach a system information file: click the File tab, then the "?" symbol at the top right, choose About, and click Write system info.
If the document is confidential, you can send it to forum[at]softmaker.com instead; please include a link to this post in your e-mail.
I am attaching the .docx file, along with a PDF showing how it is supposed to appear.
sminfo.txt
(25.48 KiB) Downloaded 156 times
Newsletter_2026-10.pdf
(421.51 KiB) Downloaded 173 times
Newsletter_2026-10.docx
(245.17 KiB) Downloaded 162 times
To summarize the issue:
The format of this document (which I publish monthly) use the full margin width of the page for the headlines of each article, then I switch to two columns for the body of each article. Sometimes (depending on the lengths of articles) I change back to one clumn for a new headline, and then back to two columns again -- on the same page -- for the body of a second article.
In Microsoft Word, this is easily accomplished by entering "Continuous" section breaks. But TextMaker doesn't work the same. Regardless of whether I enter a "Section break" or a "Chapter break," entering either type of break automatically sends me to the top of the next page. TextMaker doesn't appear to offer a type of section break that allows me to remain on the same page but change the number of columns in the new section.
Thank you for the files and for your patience. The problem is that Word's continuous section breaks, which allow the number of columns and the page layout to change in the middle of a page, are not yet converted correctly by TextMaker. This affects both directions: opening such a DOCX file in TextMaker, and saving a TextMaker document with a mid-page column change as DOCX, as you showed in your test in the other thread. I have forwarded your report, together with your newsletter file and the PDF of the intended layout.
Within TextMaker itself, you can usually get a two-column article body on the same page as a full-width headline without inserting a break: select the body text of the article and choose the number of columns via the arrow of Layout | group Section | Columns. TextMaker then creates the required sections automatically, and by default they do not start a new page (see What are sections?). This does not solve the exchange with Word, but it may help when you edit the newsletter in TextMaker.
Return to “TextMaker for Windows”
