I’m having a problem:
Previously, I permanently deleted the template formatting (Times New Roman font) and replaced it with a new template I created myself. I then set this as the default.
Sheet 1 displays perfectly normally. However, when I add a new sheet, it doesn’t display correctly (see image). From Sheet 2 onwards, when I select the template I saved, those sheets are automatically deleted, and only Sheet 1 remains visible.
What is happening? Is this a bug, or have I done something wrong? I’m really frustrated that Sheets 2 and above aren’t behaving as expected.
Planmaker NX 2024 Mobile.
Android 13, Galaxy A04 S
A strange problem: Sheets 2 and above do not conform to the file template format I saved.
Văn Quang Nguyễn VN
Last edited by Văn Quang Nguyễn VN on Sun Sep 20, 2026 9:01 am, edited 1 time in total.
Văn Quang Nguyễn VN
Re: A strange problem: Sheets 2 and above do not conform to the file template format I saved. They do not display in the
Other
I think this is definitely a software bug.
You saved it as a Template (Planmaker) and set it as the default. You did this correctly; there’s nothing wrong with that. If you had done it incorrectly, when you closed the document and reopened it, the software wouldn’t follow the template.
But this time, when you added a new sheet, Planmaker didn’t follow the template you saved. Only Sheet 1 followed it.
Even stranger: on Sheet 2 and beyond, when you select the template, these sheets are automatically deleted.
This is definitely a bug. I think this issue should be fixed so that every sheet adheres to the template saved by the user. And the problem where selecting the template on Sheet 2 and beyond causes those sheets to be automatically deleted—leaving only Sheet 1—needs to be resolved completely.
I love Softmaker and won’t use any other software
I love the Softmaker file format. I I really like Softmaker software because the software updates always include new features
I realized that Planmaker’s default template format used to work very well. Whenever a sheet was added, it adhered to the format.
But you permanently deleted that and replaced it with a new template format you created yourself, and Planmaker no longer adheres to it. It only adheres to the format on Sheet 1; any sheets added afterward do not follow it. They automatically change the font and font size. And when switching to the user-created template format, the added sheets are automatically deleted, leaving only Sheet 1.
I think this issue needs to be resolved as soon as possible. I’m not sure if this happens on other computers or operating systems, since I don’t have many machines or OSes. I hope the Softmaker team can help me investigate this issue. I’m concerned it might occur on other operating systems as well.
Thank you to the Softmaker team for taking the time to read this post. This is a serious bug.
A document template is used as the basis for creating a new PlanMaker document; it is not reapplied whenever you insert a worksheet. To set the default font for every worksheet, edit the “Normal” cell style via Home | Format | Cell styles | Manage cell styles, save the file as a PlanMaker template, and set it as the default. Selecting a template through File | New creates a new document, which is why only its original worksheet appears.
Văn Quang Nguyễn VN
However, when I add a new worksheet, the cell width and height are Not compliance as per Sheet 1. The template I created changes the width and height of all cells. What should I do? I have successfully set the default font for all worksheets.
- Screenshot_20260920_135607_Office PlanMaker.jpg (14.09 KiB) Viewed 3880 times
Văn Quang Nguyễn VN
Other
Văn Quang Nguyễn VN
The colour of Sheet 1. When a new sheet is added, this setting is not applied.
I have also deleted that template (Times New Roman). I have deleted it permanently. The only template left is the one I created myself, which includes changes to the font, font size, the size of all cells, and the sheet colour, which is yellow.
