Default file when program starts
wtin
Post by wtin »
First of all, I would like to state that although I do not use your program that often at all, as I use Corel Ventura Publisher and Adobe FrameMaker, every time a new version comes out, I buy to support the company as the price is extremely reasonable.
What really annoys me is the Welcome to TexMaker template pops up every time I start the text program. I go into the Documents folder and delete it, and it still gets created.
I look at the customization and settings and cannot find it. Maybe I'm too impatient to get this sorted out. Someone please help. It is very annoying and I don't need to see it more than once.
wtin
Re: Default file when program starts
Post by wtin »
This original question was read over 3,000 times and yet not even one reply from the company.
How disappointed to have continued to support this program, which I don't even use on a regular basis.
Maths
Post by Maths »
Please try to be patient. Sometimes they’re too tired from work to respond. Or they might be busy working on the new NX 2026 mobile version.
Just be patient. Right now, that’s the only software that can meet the need to replace Microsoft Office. I’ve also submitted many feature requests.
Please wait. Don’t leave. Show some respect for the hard work of the Softmaker staff. Maybe they’re just too exhausted to reply, or they’re swamped with work.
I love Softmaker and won’t use any other software
I love the Softmaker file format. I I really like Softmaker software because the software updates always include new features
Maths
Post by Maths »
They'll probably check the forum again and reply to you. Don't worry.
lgsl
Post by lgsl »
wtin wrote: Mon Sep 07, 2026 3:31 am This original question was read over 3,000 times and yet not even one reply from the company.
You realise this forum in visited by bots all the time and most likely 99% of the views of your post wasn't by humans?
The file you speak is created the first time you lunch a new version. Once you remove it it should not appear again as long as you don't remove the SoftMaker folder or upgrade to a new version.
Maths
Post by Maths »
How do you know that? Is that really true?
To be honest, there was a post from back in May, and they didn’t respond until August (based on the Vietnamese calendar, since I live in Vietnam). Softmaker is very responsible. If they haven’t responded to a post yet, they will respond and apologize if it takes too long. Softmaker doesn’t delete posts indiscriminately.
Here’s a real-life example:
Lately, I’ve been posting feature suggestions. They didn’t respond. When I posted another one, they asked me to hold off while they reviewed it. This shows they do listen to users, but they’ll quietly take note.
I can assure you: Softmaker has likely already taken note of your post. Softmaker is very responsible. For any post that’s been up for a month without a response, they will respond and offer a sincere apology.
It’s best to leave this post alone. Softmaker has likely already quietly taken note of it. They may have a heavy workload and be exhausted, so they can’t respond to every single post.
This topic was inadvertently missed during our normal forum review process.
The Welcome to TextMaker.tmdx document should normally appear only during the initial use after a new installation.
Please close all SoftMaker Office applications and rename the Documents\SoftMaker folder, for example, to SoftMaker-old. Do not delete this folder, as it contains your customized settings, templates, dictionaries and other user files.
When you start TextMaker afterward, the welcome document is expected to appear once because a new SoftMaker folder is created. Please close TextMaker and open it a second time. The welcome document should not appear again.
Please let us know whether it reappears on the second start.
Return to “TextMaker for Windows”
