I am researching a book about free software for struggling authors. The idea is to suggest and to discuss various types of software that can replicate the overall functionality of a commercial writing product called Scrivener, which incorporates word processing with an outliner and a note taking function. Think of it as being sort of like Microsoft Word and OneNote, all combined into a single package.
There is no other single package that really matches Scrivener. A word processor plus something like OneNote (or a clone of OneNote) would do it. FreeOffice TextMaker would be ideal as the word processing component. Most writers rarely need a spreadsheet and almost never need a presentations program. Is it possible to install only the TextMaker module out of FreeOffice? If so, how is that done?
Thank you.
TextMaker only?
TextMaker only?
Re: TextMaker only?
On my taskbar you seeTextMaker and PlanMaker. I both use them on a daily basis.
If you only use TextMaker, just pin that one to the taskbar and leave the rest invisible.
Problem solved.
Problem solved.
Re: TextMaker only?
How does that in any way solve the problem of not wanting unused programs installed on a computer?Léon wrote: Tue Aug 25, 2026 9:53 pm If you only use TextMaker, just pin that one to the taskbar and leave the rest invisible.
Problem solved.![]()
Re: TextMaker only?
As long as your computer is not full, unused program parts are no problem at all.
Re: TextMaker only?
Suppose space is a consideration?Léon wrote: Wed Aug 26, 2026 8:09 am As long as your computer is not full, unused program parts are no problem at all.
Do you have an answer to the question, or not?
- Contact:
Re: TextMaker only?
This is one very weird thread that could have been totally avoided by starting the setup, choosing a custom install and seeing that you can select TextMaker, PlanMaker and Presentations independently.
Re: TextMaker only?
Thank you, Martin. That's the answer I was looking for.martin-k wrote: Wed Aug 26, 2026 11:28 pm This is one very weird thread that could have been totally avoided by starting the setup, choosing a custom install and seeing that you can select TextMaker, PlanMaker and Presentations independently.
