Planmaker is error
Văn Quang Nguyễn VN
Planmaker is error
Post by Văn Quang Nguyễn VN »
I found a small bug: When I unchecked the "Show page breaks" in the View tab. Then the horizontal line and the vertical line disappeared. But when you go to the File tab, select New, a new spreadsheet appears, but horizontal and vertical lines appear, and the "show page breaks" option pops up again. I also don't know how to make this option permanently disabled. Hope to fix this error.
Android 13
Uncheck "show page breaks"
Last edited by Văn Quang Nguyễn VN on Sun Aug 09, 2026 1:59 pm, edited 2 times in total.
I didn't know much about the English language, so I had to use a translation tool. I love Vietnam. My hometown 🇻🇳 🇻🇳 🇻🇳 🇻🇳
Văn Quang Nguyễn VN
Re: Planmaker is error
Create a new spreadsheet, but this option pops up again<br /><br />Office nx Planmaker 2024
Văn Quang Nguyễn VN
Specifically, I use the galaxy A04s product of the android version 13
Formula Use
Post by Formula Use »
I’ve encountered this error too
I live in Vietnam. My homeland is a land of green coconut palms and gently flowing rivers.
Ho Chairperson set out in 1911 to find a way to save Viet Nam country.🇻🇳
Formula Use
I don’t know how to fix this error either. I want to remove the horizontal and vertical lines permanently.
stascheit
Post by stascheit »
This is a document option and not a global setting. You cannot uncheck it generally for all documents.
But you can save the "Normal.pmvx" template with this option unchecked, then all new documents based on "Normal.pmvx" (this is the default template when you open PlanMaker) will open with this option unchecked.
Return to “PlanMaker NX for Android”
