Polish letters "ć" and "Ź"
Janusz
Post by Janusz »
It's impossible to type Polish letters in the usual way: lowercase "ć" (right Alt+C) and uppercase "Ź" (right Alt+Shift+X).
This is likely due to SoftMaker Office NX misinterpreting the codes for these key combinations received from Windows because:
- The "Tools / Unicode to Hex Value" command has the shortcut Alt+Ctrl+Shift+X, and pressing the combination (right Alt+Shift+X)
doesn't display the uppercase "Ź" but executes the above command.
- The "Format / Copy Formatting" command has the shortcut Alt+Ctrl+Shift+C, and pressing the combination (right Alt+Shift+C)
doesn't display the lowercase "ć" but executes the above command.
The same applies in TextMaker and Presentations, but only for the Alt+Ctrl+Shift+X shortcut.
You can change these shortcuts, but not everyone will figure it out, and the first impression will be that the program
is not working properly.
Re: Polish letters "ć" and "Ź"
Thank you for the detailed report and for tracing it back to the shortcut assignments. I can reproduce this issue.
As an immediate remedy, the two shortcuts can be cleared or reassigned under Tools > Customize > Search for "Copy formatting" and "Unicode to Hex value"> remove these shortcut keys, after which both letters are entered as expected.
I agree that this should not require manual intervention, and I have forwarded the report.
Return to “BETA: PlanMaker NX and 2026 for Windows”
