NEW USER with a question about footnotes
LarrySmith77835
Post by LarrySmith77835 »
I am an author trying to use TextMaker to create a PDF file for my book. I am currently using the free version of TextMaker. I use footnotes in the book to add information that is not part of the story. I have looked for help about adding footnotes and now believe that I must purchase the SoftMaker Office suite to be able to use footnotes.
If this is not true, please tell me how to use footnotes in the free version.
Thank you in advance for your help.
Regards,
Larry
Re: NEW USER with a question about footnotes
https://forum.softmaker.com/viewtopic.php?t=29084
This also works in the Windows version.
In the future, questions about FreeOffice should be posted to the FreeOffice discussion area. You posted in the area for discussing the beta test version of SoftMaker Office 2026.
LarrySmith77835
Thank you, Woody, for your reply. I have found a solution to my problem in the thread you suggested.
And I appreciate your information guiding me to a more appropriate thread.
Regards,
Larry
Return to “FreeOffice TextMaker 2024 for Windows”
