Beta 2 fails to install on CachyOS (arch linux)
markr
Post by markr »
Beta 1 installed with no problems but Beta 2 loops getting "Permission Denied" errors because it is attempting to modify the /usr directory without root permission. Previous versions only modify /home.
markr
Re: Beta 2 fails to install on CachyOS (arch linux)
Post by markr »
Apparently version 1417 did install but for some reason the install script is in an endless loop attempting to modify /usr.
joegnsx
Post by joegnsx »
failed for me too using Windows
Thanks for your post — I've forwarded the details for further investigation.
For the Windows issue, could you share a bit more detail, with a screenshot of exactly what happens when installing the Beta (S1417) — the precise error message or where it fails? That'll help us diagnose it.
Our developer team has fixed this issue in the release versions.
Return to “Beta announcements”
