Black cursor on black background
mjwhite
Post by mjwhite »
The cursor in Presentations on Linux is black even when the colour theme is also black - so isn't visible.
(This has been for in previous releases too - it'd be great to see it fixed. The equivalent happens in the other apps too, I think, but doesn't occur so often.)
Re: Black cursor on black background
Thank you for your post. Please share a screenshot of the application for a better understanding.
On some Linux distributions, the cursor is black by default with a bright white outline, which remains visible in dark mode as well — this applies to all applications, not just SoftMaker Office.
In that case, you can check other applications and customize your mouse cursor at the operating system level.
mjwhite
Post by mjwhite »
Ah, apologies - I meant the text cursor, not the mouse cursor. This has I think been the case for at least the last 3 major SoftMaker releases on Linux, across a few distributions and desktop environments.
Screenshots attached, though they're not very exciting - with a white theme you can see the text cursor after "Hello!" (it blinks of course); with the black theme you can't ever see it. On other-colour themes the cursor remains black, so I guess it's invisible here for the same reason.
Composite of black and white backgrounds
Regarding the black background, I can reproduce the issue and have forwarded the details for further investigation.
Return to “BETA: Presentations NX and 2026 for Linux”
