An old problem
mondorocco
An old problem
Post by mondorocco »
I bought and used yours. office software years ago, I am testing the new NX version and I must say that you have done a good job, especially with the interface, but there is still a problem, compatibility.
This is the reason why I had to abandon your project. The only one.
I am attaching a file of an article I wrote with Word 2021, open it with yours and you will see with your own eyes.
If the compatibility problems are resolved I will be happy to buy and use your product. (I prefer the European ones).
Greetings
Io gemini e altri 4 (Parte I).pdf
(1007.16 KiB) Downloaded 12 times
Io gemini e altri 4 (Parte I).docx
(169.99 KiB) Downloaded 10 times
Re: An old problem
Thank you for sharing the sample files. To better understand your issue, could you please provide a brief explanation of the problem?
A screenshot would also help diagnose it more accurately.
Re: An old problem
A quick look should show you that the font metrics don't match. This upsets the lineation, which in turn upsets the pagination. This has been a long-standing problem, about which I have commented previously.
Return to “BETA: TextMaker NX and 2026 for Windows”
