When I copy and paste text from Textmaker into Presentations and then try to change the font size in Presentations, it does not change correctly. Most of the time is stops at 27.5 pt. I repeated this on 2024 (not NX) and the font changes correctly. I have attached the two files I am working with. Hopefully it can be repeated for you.
Process I followed:
1. Copied text from ChatGPT.
2. Pasted Text into Textmaker Beta.
3. Formated the text.
4. Copied bullet points into Presentations.
5. Tried to change font sizes in Presentations. Did not change
6. Went to the Master Slide to change font size. Did not change
7. Saved files and reopened and repeated the process. Did not work.
8. Gave up and went to 2024 to complete the slides for my class. This worked.
Font Size Change Not Working
- Building confidence in yourself.pptx
- (34.82 KiB) Downloaded 139 times
- Building confidence in yourself.docx
- (18.54 KiB) Downloaded 138 times
Re: Font Size Change Not Working
Udate:
I found the problem. In the object properties box I needed to select "Do not auto fit" in the Autofit options.
My apologies.
My apologies.
Thank you for following up and sharing the solution — this is actually a very common point of confusion, and your note may help other users encountering the same behaviour.
