Error code 2330
GuernseyMan
Error code 2330
Post by GuernseyMan »
When I try to install the 10th beta I get the error code 2330.
I'm running Windows 10 Enterprise LTSC if that makes any difference.
Also, as I'm installing onto a new windows install I need my beta key, unfortunately I've erased my original email so don't have access to it. Is there a way to recover this?
Re: Error code 2330
Please share the screenshot of your error.
Please click on get it free in the shop from below link to get the new product key for Beta.
https://www.softmaker.com/en/products/s ... ffice-beta
GuernseyMan
Re: Error code 2330
Thanks, I have a key now.
My error is:
GuernseyMan
Re: Error code 2330
I also get this error when I try to install the non-beta version as well. It's probably my system that is at fault so I will do some more checking.
GuernseyMan
Re: Error code 2330
Installed it on a fresh windows system and it worked fine. Must have been something it didn't like with my setup as I had the same error with the current installer.
Thanks for your help.
Re: Error code 2330
Error 2330 is a Windows Installer permission issue — Setup cannot read file attributes, often due to folder permissions or your Documents path. Right-click the installer, choose Run as administrator, and ensure your user has full permissions on the target folder.
Return to “BETA: TextMaker NX and 2026 for Windows”
