Setting the default font and size not working
liljequist
Post by liljequist »
Hi,
when I follow the instructions from the site:
https://www.freeoffice.com/en/support/t ... /textmaker
"If you would prefer to start your documents in a different font to Times New Roman 10 pt, you can easily change it. Simply right-click in the document window to open the context menu and select the menu entry Character. In the dialog box "Character", you can now select your preferred font settings and make them your new default settings by clicking on the Set as default button. In the following dialog box, select Change for all new documents based on the default template. All future documents based on the default template will now use the selected font settings."
Even so, when I create a new document, Times New Roman is still pre-selected as the font. What could be the reason for this? Please don't say it's my stupidity ;-) Any help is welcome.
Lljequist
Re: Setting the default font and size not working
We are not able to reproduce the steps. Please follow the steps carefully.
Are you certain you are following the steps? I had no trouble changing the default font.
liljequist
Thank you so much.
Yes, I follow those steps exactly. In particular, I select "Set as default" and "Change for all documents..." My preferred font is "Tahoma". Then I save the document and open a completely new one, and again "Times New Roman" is the selected font.
Liljequist
That's strange. Please reinstall FreeOffice and then check again.
liljequist
Thanks for the suggestion. What I've discovered in the meantime is that changing the default font works as an administrator, but not for other windows users without administrator privileges. I usually work as a non-admin because I consider that somewhat safer. Is there a way to change the aforementioned setting even in that case? Where does SoftMaker store the file in which such settings are saved?
Liljequist
We were able to change the default font even on a non-administrator user account without any issues.
If you believe administrator rights are causing a problem for you then please try right-clicking on TextMaker and selecting Run as Administrator.
liljequist
Thank you and sorry for the late reply. Starting Textmaker as administrator allowed me to permanently change the setting.
Return to “FreeOffice TextMaker 2024 for Windows”
