Line spacing in bullets
Tardis40
Post by Tardis40 »
I have some rather long areas of text that has bullet points about every 3-4 lines. I'd like to have a bullet setting that increases the line spacing between the text above and start of a new bullet point to make the bullet points stand out more. Is that possible?
I know I can create a new line, delete the bullet and then create a new bullet text but I have several pages of bullet points and hoped I could just change the setting for that setting.
Re: Line spacing in bullets
Post by Jossi »
As every bullet starts a new paragraph, you can solve this via paragraph format by inserting an appropriate paragraph spacing before.
Tardis40
Post by Tardis40 »
Thank you. I hadn't thought of that.
JohnWasilewski
Post by JohnWasilewski »
Funny, isn't it, how our preferences differ?
That must be why they’re called ‘preferences!’
Your member “Tardis40” would like a slightly larger line space immediately before a first bullet point, to make the bullet list more distinctive. I prefer the exact opposite.
I always fiddle with paragraph settings make line spaces visibly slightly smaller immediately before a first bullet point. This is to join the bullet list more obviously to its ‘parent' paragraph above. I also also slightly increase the list’s separation it from the paragraph that follows.
I for one would find it really, REALLY helpful to have a global setting that could be used to obtain automatic slight widening or tightening of line spaces by some +% or -% immediately above and immediately below every bullet point list in a document. It is these kinds of attention to every tiny detail of users’ needs that lifts SoftMaker Office into a class above its competitors.
Go to the Format > Paragraph dialogue. Scroll down the list of paragraph style until you find "List bullet." Make changes until you get what you want.
Return to “TextMaker 2024 for Mac”
