Font issues on linux
Alister
Post by Alister »
I'm not sure how FreeOffice tries to find fonts on Linux, but it doesn't work quite right.
Using FreeOffice on NixOS I find it doesn't see most of the fonts installed on my system - there are a few that it lists, but doesn't actually seem to read them (I can tell for sure because "Arial Black" is just something skinny, obviously not arial black).
The workaround is to copy or symlink all my fonts into
Code: Select all
~/.local/share/fonts
On a somewhat related note, in many cases the rendering is quite poor with antialiasing disabled - I'm guessing it does its own font rendering, and doesn't use BCI hinting.
Re: Font issues on linux
For best results, please use one of the supported Linux distribution listed here.
Alister
Post by Alister »
Yes, on Debian there is no problem finding the system fonts, although the rendering isn't any better.
For anyone else just wanting to find a font that renders well, try obtaining the real Calibri (easy enough on some distros, which extract it from Microsoft powerpoint viewer). By default you will likely have a fake "Calbibri" available, which is really Carlito, using font substitution.
