Textmaker select text
Adri
Post by Adri »
I can not select text as written in manual pag 65.
Also <ctrl-a> does not have any effect.
I am surprised: basic function.
Does anybody recognise it?
el48tel
Re: Textmaker select text
Post by el48tel »
I'm not finding this issue.
Opened an existing document in WORD.
Copied it
Opened new document in Textmaker
CRTL-V
No problems pasting it.
CTRL-A
CTRL-C
CRTL-V
Closed it
Opened it
No problems
Created a new empty document in Textmaker
Wrote a few lines
CRTL-V
Adri
Post by Adri »
Thanks el48tel.
I immediately verified and you’re right of course. I am happy.
Two remarks:
I had an update, but I can not imagine that was the solution.
The selection I made are not clear on the screen.
So I replaced on another PC also TextMaker: functions work and are visible.
I will investigate how to change the visibility win-pc.
Return to “BETA SoftMaker Office 2024 for Windows (general)”
