First let me apologize for posting this in the English forums. I tried to login into the German forum but no go! I suspect I need a second login? As I already do have about 150 of them I try to keep them to a minimum.
I have downloaded the 2010 beta yesterday and tried to install it. The first time I had to abort the install (Nicely using the Abort button) Now I am not able to install it anymore After I reach the screen with the file associations Windows Vista is telling me the MSI is closed by DEP. DEP is set to only check the basic Windows files, so I can't change it for better.
Is there anyway to install the Beta anyway?
Your Dutch translator
SoftMaker 2010 Beta
Arno Verhoeven
Arno Verhoeven
Re: SoftMaker 2010 Beta
Post by Arno Verhoeven »
Hi,
just wanted to let you know.... I solved the problem by choosing a different installation language and a specific setup instead of the full setup.
- jimjutte
- SoftMaker Volunteers
- Contact:
Interesting solution. Any possibility that it might be related to the language of the actual download?
Cheers
Jim
Jim
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
