Are there any plans to compete/blow Microsoft out of the water with a Project Management program? Or possibly add a few features to PlanMaker that can give some ability to handle some PM tasks?
There are some free tools out there but they are not for the novice (i.e. installing Python or JRE and executing the initial startup from a command line, lack of good documentation, etc. so free is no competition). However, MS Project costing around $600 for a new edition and $400 for an 'upgrade' for the 'standard' edition and $600/$1000 for the Professional (ability to work in a server environment with Project Server).
There is no real gap filler. It's either free and marginal at best, or nice and Microsoft expensive.
The closest thing I did find that is a possible tool is ToDoList but that is more of a 'Get it Done' type of tool. While you can do quite a bit with it there are key features not there as it was not intended to be a project management program. Features like various charting (gantt, etc) or reporting methods are not there.
I did a search in the forums and only found one hit regarding a Project Management tools and that was almost 4 years ago.
I would think that such a tool would be quite popular if it met or exceeded MS Project for a lower cost such as your current office suite.
Many thanks in advance, and keep up the great work with your software!
MShideler
Project Planning tools?
Re: Project Planning tools?
Currently there are no plans to develop an Project Planning tool like MS Project.
I would like to see a Project Management offering from SoftMaker.
But, until then, you might want to check out Plan for Windows by Twiddlebit. The cost is currently $39.95. (I'm not connected to the company. I'm just a customer.)
Code: Select all
http://www.twiddlebit.com/
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
