This post is intended as a user guide, not spam.
1. Text Direction
Microsoft Office has a redundant feature called "Text Direction." This feature forces users into fixed templates and does not allow for angle customization. I hate Microsoft, and that’s why I don’t use their software. I only love Softmaker.
Instructions:
Step 1: Go to the Insert tab; select Text Art
Step 2: Enter text into the top box in the dialog box. Then select black text with no shadow.
Step 3: Once the object has been inserted onto the page, the Object tab appears. Simply use your mouse or finger to tap the rotation button and rotate it.
]2. Creating water mark text
Step 1: Go to the Insert tab > Text Art
Step 2: Enter text into the blank field at the top of the dialog box; select black text with no shadow
Step 3: Right-click. The context menu appears. Select the last option. On the Fill tab, set the opacity to 90% or higher. On the Line tab, select the Single Line style with a width of 0.25 pt, 0.5 pt, or 0.75 pt. Then adjust the opacity in the Options section to 90% or higher. Make sure the value matches the one on the Fill tab
Tip: How to create water mark text and text direction in Textmaker, Planmaker and Presentation
Văn Quang Nguyễn VN
Post by Văn Quang Nguyễn VN »
1 post
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
