[Suggested improvement] Softmaker file formats (Textmaker, Planmaker, Presentation) do not have icons. When using the ph
Văn Quang Nguyễn VN
Post by Văn Quang Nguyễn VN »
Currently, once I have finished saving files in the Softmaker( tmdx, pmdx, prdx) and Template formats (Softmaker) for Textmaker, Planmaker and Presentation
However, the problem is that when I tap on the file, a message appears (see Figure 1), It says the file cannot be opened. I have to use open Textmaker, Planmaker or Presentation and use the ‘Open’ function to access the file. This is very inconvenient. As I am already in the file manager, having to use a different method is very time-consuming. This issue needs to be resolved so that the file opens immediately upon tapping.
The second issue: After saving the file, when using the phone’s file manager, the files saved in the Softmaker format do not display their correct icons. Instead, a different icon appears (see Figure 2). This needs to be improved.
3.
In Textmaker’s ‘Browse’ window, the ‘Presentation’ must ensure that all files display an icon. Currently, none of the files display an icon in the ‘Browse’ window of the ‘Open’ function.
Figure 1
Figure 1
Figure 2
Figure 2
Screenshot_20260919_132412_My Files.jpg (3.3 KiB) Viewed 1132 times
I didn't know much about the English language, so I had to use a translation tool. I love Vietnam. My hometown 🇻🇳 🇻🇳 🇻🇳 🇻🇳
Văn Quang Nguyễn VN
Re: [Suggested improvement] Softmaker file formats (Textmaker, Planmaker, Presentation) do not have icons. When using th
I have edited the post
