The following are the new features for the filtered Ribbon interfaces:
(These interfaces will be optional)
1. Ribbon A1 (light)
When this interface is selected, a green rectangle will immediately appear that fits perfectly around the selected tab. Whichever tab is selected will be enclosed by that green rectangle, which fits perfectly. The tab name will be white. This applies equally to Textmaker, Planmaker and Presentation.
2. Ribbon A2 (light)
When this interface is selected, a yellow square will appear, perfectly enclosing the selected tab. The tab name will be white inside the square. This applies equally to Textmaker, Planmaker and Presentation.
3. Ribbon A3 (Light):
When this interface is selected, a black triangle with its tip pointing upwards will appear, perfectly enclosing the selected tab. The tab name will be white inside the triangle.This applies equally to Textmaker, Planmaker and Presentation.
4. Ribbon A4 (Light):
When this interface is selected, a purple circle will appear, surrounding and fitting snugly around the selected tab. The tab name will be white within the circle.This applies equally to Textmaker, Planmaker and Presentation.
The remaining themes:
If there is a light ribbon theme, there must also be dark ribbon themes:
+ Ribbon A1 (Dark)
+ Ribbon A2 (Dark)
+ Ribbon A3 (Dark)
+ Ribbon A4 (Dark)
They function identically and there are no differences. However, other areas within the software will be dark. The shapes surrounding the command tabs function in the same way. Here is an example:
Select the Ribbon A4 (Dark) interface. Immediately, other areas of the software will turn dark. Whichever tab you select will be enclosed by a purple circle that fits perfectly. The command tab’s name appears in white text.
[ Eight new features] for Softmaker Office NX, Softmaker Office and FreeOffice
Văn Quang Nguyễn VN
Post by Văn Quang Nguyễn VN »
1 post
Return to “SoftMaker Office for Windows (General)”
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
