While using the software, I noticed that some features were missing. That’s why I submitted a feature request. I’ve submitted requests before, but haven’t received any feedback yet.
Features for TextMaker and presentations across all computer and mobile operating systems (FreeOffice, SoftMaker Office NX, SoftMaker Office)
Important View Mode
The "Important View" mode is a very useful feature that Microsoft has never implemented. This feature helps users search quickly without wasting time.
And the way it works is very simple: Just select "Important View" mode. Immediately, a dialog box appears asking what to search for. After filling in the blank, Textmaker and Presentation will quickly search based on the specified criteria. If the user enters a general term—for example, “Customer”—the results will include everything. However, the location of that phrase remains fixed and never changes. If the user specifies a more precise search, the results will match the intent exactly. Irrelevant content will be filtered out.
If the user decides they no longer need this feature, they can simply disable it. The document will revert to its original state, without losing a single character.
What’s special is that this feature works just like Planmaker’s Auto Filter feature.
For Textmaker, Planmaker, and Presentation
Toolbar Color Change Feature
Currently, your software supports the ability to change the color of the workspace, except for the page. Therefore, adding a toolbar color-changing feature would fill in the remaining gap. Specifically, this feature will be located in the Interface tab under the Options menu
A simple color palette will be available, along with a “Define Color” option. This feature will allow users to change the color of the toolbar. For example, on the “Home” tab, the toolbar—which contains features such as “Cut,” “Copy,” “Format Painter,” and so on—will stand out clearly, while the toolbar’s color will now be purple. The same applies to other tabs.
Title Bar Color Customization:
This is an extremely useful feature. Adding this feature essentially completes the customization capabilities. This feature will also be located in the Interface tab under the Options menu. It allows users to quickly change the title bar color using the built-in color palette or to choose their own color using the Define Color feature. And to ensure consistency, After changing the title bar color, the software logo and the color of the selected command tab will match the new title bar color.
Thank you very much for taking the time to review my suggestions. I hope the features I’ve proposed will be available on both mobile and desktop devices, operating smoothly and with 100% accuracy.
[Feature Suggestions] for Textmaker, Planmaker, and Presentation
Formula Use
1 post
Return to “SoftMaker Office for Windows (General)”
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
