Launch only one instance of PlanMaker
ag_me
Post by ag_me »
If I open a spreadsheet, from File Explorer, an instance of PlanMaker is launched and if I then click on another spreadsheet in File Explorer another instance of PlanMaker is launched.
Where can I configure that PlanMaker will use only one instance to work on multiple spreadsheets ?
Re: Launch only one instance of PlanMaker
In PlanMaker, click directly on File | Open to display the Open dialog, clear the New program window option, and open a spreadsheet. This setting is saved and subsequently applies whenever documents are opened. Further spreadsheets opened from File Explorer should then appear as tabs in the existing PlanMaker window.
Return to “SoftMaker Office for Windows (General)”
