How do I insert a document in one tab into a document in another tab?
MikeyInCVCA
Post by MikeyInCVCA »
Hi,
Using FlexiPDF 2025 (Version 2025.420.0626-64 bit), I was merging PDFs created by a scanner, where I had to rotate some pages and do a bit of cropping. I wanted to end up with a single PDF.
At one point, I had all the pages except one in the first tab of FlexiPDF and a single page in the second tab, which I wanted to insert into the middle of the document in the first tab.
I couldn't find a way to "insert document from another tab." I finally had to Save the document in the second tab to a file, then Insert Document from File into the first tab.
Certainly there's something I've overlooked that would allow me to merge the contents of two tabs in a single FlexiPDF window? ...thanks!
Re: How do I insert a document in one tab into a document in another tab?
Thank you for posting your query. FlexiPDF cannot insert pages directly from another open tab.
Your method is correct: save the source PDF, then select Pages | group Insert | From document in the destination PDF.
To combine complete files instead, use Document | group Edit | Join, add the PDFs, arrange their order, and click Join.
