Update my pro 2024 to New 2026?
myoffice
Post by myoffice »
Howto made an update from version 2024 to new 2026?
I have lot setting i dont want to config again.
I have made custom templates for both PlanMaker and TextMaker.
Re: Update my pro 2024 to New 2026?
You can install SoftMaker Office 2026 alongside Office 2024 and transfer your settings as follows:
  1. In an Office 2024 application, choose File | Options | Manage.
  2. Select the settings you want to transfer, click Export and save the generated ZIP file.
  3. Open the corresponding Office 2026 application and choose File | Options | Manage.
  4. Select the same categories, click Import and choose the exported ZIP file.
  5. Restart the Office 2026 applications.
Custom templates are not included in the settings archive. Check the template folder location under File | Options | Files in TextMaker and PlanMaker, then copy your custom templates to the corresponding Office 2026 template folders.
More details are available in the TextMaker 2026 online manual under Customizing TextMaker | Exporting/importing settings.
Return to “SoftMaker Office for Windows (General)”
