[Feature Request] Formula Auto-Suggest / Intellisense dropdown in PlanMaker (Desktop & Mobile)
Formula Use
Post by Formula Use »
Hi SoftMaker Team,
First of all, thank you for developing such a great office suite!
I would like to request a quality-of-life feature for PlanMaker on both Desktop and Mobile (Android/iOS): Formula Auto-Suggest (or Intellisense) when typing in cells.
Current Behavior:
Currently, when typing a formula like =I, users have to memorize and type out the entire function name manually, or open the Insert Function dialog. This can be especially inconvenient when working on smartphones or tablets.
Suggested Improvement:
When a user types = followed by initial letter(s) (e.g., =I), a drop-down list of matching functions should automatically appear (e.g., IF, INDEX, INT, INDIRECT...).
It would be great if users could:
Navigate through the suggested list using arrow keys (on Desktop/Keyboard) or tap to select (on Mobile).
Press Tab or Enter to auto-complete the selected function name.
See a small tooltip or popup showing the syntax and brief description of the selected function.
Bringing this feature to both PC and mobile versions of PlanMaker would significantly speed up data entry, improve the user experience on touchscreens, and bring it closer to standards set by Excel or Google Sheets.
Thanks for considering this request!
Best regards,
Văn Quang Nguyễn VN
Re: [Feature Request] Formula Auto-Suggest / Intellisense dropdown in PlanMaker (Desktop & Mobile)
Post by Văn Quang Nguyễn VN »
I agree with this feature. Should be added
Thank you for your post. I have forwarded this improvement suggestion.
Return to “SoftMaker Office for Windows (General)”
