Mathematical formula insertion feature for the mobile version
Formula Use
Post by Formula Use »
I live in Vietnam and have been using your software for a long time. I’ve had to use a translation tool to write this post. On the Play Store, there’s an app with an interface similar to the desktop version: Mobioffice. However, the problem with this app is that when you type text and then delete two words, When I type new words, the two old ones reappear. I decided to switch to SoftMaker Office NX. The software is excellent and runs smoothly. However, the mobile version still lacks the ‘equation’ feature found on the desktop version. For a mobile app, the absence of this feature is a major inconvenience. I’ve had to use a website to compose mathematical equations. I had to take a screenshot, crop it, and then insert it into the software. This was a real time-waster. Other apps already have this feature, so why is it missing from yours? I hope you’ll add this feature to the software. It would be a great help to many users and save a lot of time. Kind regards
Văn Quang Nguyễn VN
Re: Mathematical formula insertion feature for the mobile version
Post by Văn Quang Nguyễn VN »
I agree with this feature. Should be added
Formula Use
The steps I follow to insert mathematical equations into TextMaker. It takes a great deal of time compared to doing it on a computer. I also hope that the Equation feature will be available for TextMaker, PlanMaker and Presentation.
Record_2026-08-18-09-15-24.mp4
(34.31 MiB) Downloaded 88 times
Formula Use
That was my feature suggestion, and the video was simply to illustrate just how difficult and time-consuming it is to insert mathematical equations into the Softmaker Office NX mobile app. The video was intended to back up what I said.
Yours sincerely,
Thank you very much for considering this feature
Văn Quang Nguyễn VN
I also came up with this way to insert mathematical formulas into the software.
Oh dear! The fact that this involves so many steps is driving me mad, but I’ve come to terms with it for now and am waiting for the Equation feature.
I didn't know much about the English language, so I had to use a translation tool. I love Vietnam. My hometown 🇻🇳 🇻🇳 🇻🇳 🇻🇳
