Print merge button has disappeared
GuernseyMan
Post by GuernseyMan »
For the first time during the beta I needed to do a print merge.
There doesn't seem to be a print merge button either in the File tab or the mailings tab. In the mailings view there is just a single "Print ..." button, the same in the file tab:
Textmaker beta screenshot.PNG (8.17 KiB) Viewed 3938 times
When I open the same file in Textmaker 2024 it's fine:
Textmaker 2024 screenshot.PNG (10.68 KiB) Viewed 3938 times
Re: Print merge button has disappeared
Thank you for posting your query.
Once the document has been set up as a mail merge, the merged output can be printed from either print dialog — the one under the File tab or the one under Mailings. Both dialogs provide options for choosing which records to include, so you can print all records or restrict the output to a specific range or selection. The screenshot below shows the available settings.
Return to “BETA: TextMaker NX and 2026 for Windows”
