Adjust the theme color of the software to be the most suitable
Văn Quang Nguyễn VN
Post by Văn Quang Nguyễn VN »
I have a comment on the software theme and hope you will reconsider. Typically, text editing software will be Sky Blue or blue. For example, polaris office's editorial software will be Sky Blue. Ashampoo office writer will be blue,... Why FreePDF, Flexi PDF Software looks blue when textmaker is red. I don't think it's appropriate at all. I hope you will correct the textmaker with a blue theme that looks a little better and is reconciled. And FreePDF, Flexi PDF is red. Please consider this . :D
Re: Adjust the theme color of the software to be the most suitable
Thanks for sharing your thoughts on this. The colors are not chosen at random — each product in our lineup has its own signature color as part of SoftMaker's long-standing brand identity, and users rely on those colors to tell the applications apart at a glance in the taskbar, in file icons and on screen. Swapping them between products would mean breaking that recognition for everyone who has been working with our software for years.
Color preference is also very much a matter of taste, and what feels "right" varies from person to person, so aligning with what other vendors happen to use is not something we plan to do here.
Your feedback has been noted all the same, and I appreciate you taking the time to write it up.
Return to “BETA: TextMaker NX and 2026 for Windows”
