What's new for Planmaker
Văn Quang Nguyễn VN
A "stop" feature should be added in the Fill dialog. Instead of manually dragging to the cell you want to stop, now you just need to type: For example, the number 1. Then black out the entire row or column and enter it in the Fill dialog box. Do the steps above. When you arrive at the stop, just enter " e.g. 100". Save more time. Please consider this feature to add on both phones and computers.
Re: What's new for Planmaker
Thank you for your post. I have forwarded this improvement suggestion.
Formula Use
This feature is great. Is there any new information? Regarding the "Stop" feature in the Fill dialog box that the other person suggested. Enter a number in a cell, then select the entire row or column before opening the Fill dialog box.
Văn Quang Nguyễn VN
The feature proposal I submitted back in July contained an Error. I apologize for the inconvenience I caused you and hope you can overlook it. The information I sent in July was completely incorrect; I inadvertently omitted a feature during the Feature selection . I will be more careful next time.
Content :
In Planmaker, the ‘Fill’ dialogue box was missing two important features:
+ Start
+ End
The ‘Start’ feature is used to enter the data to be filled in, whilst the ‘End’ feature is used to enter the data where you wish to stop. It works in a similar way to LibreOffice Calc
If these two features were included, they would save users a lot of time. Users would simply need to select any cell, then open the ‘Fill’ dialogue box. After following the steps, they could enter the data info the ‘Start’ and ‘End’ feature. Click ‘OK’ and you’re done. The sequence numbers would be filled in automatically and quickly, from 1 to 1000. This would be very useful
If I’ve caused you any inconvenience, please do ignore it. And I’m very worried that you might complain about me.
Content :
+ Start
+ End
