Search dialog position resetting after closure
ChalkyW64
Post by ChalkyW64 »
The search dialog does not "remember" its last position during a PlanMaker session. It opens [on my system] at the bottom centre of the screen. If I move it elsewhere and have to close it, it returns to the bottom centre next time it is opened.
It would be good if it could open at its last position - particularly as it often has to be closed due to the issue with search results often not being viewable/reachable...
Re: Search dialog position resetting after closure
You're right that the Search dialog currently reopens at a fixed spot rather than where you last left it. I've forwarded this as an improvement suggestion.
Return to “BETA: PlanMaker NX and 2026 for Windows”
