Search result bug...
ChalkyW64
Post by ChalkyW64 »
When searching, the cell containing the search text is sometimes 1 row beyond the bottom of the window (i.e. rows 1-20 are displayed and the search result is in row 21). Because the search dialog is opened modally, the only way to scroll down 1 row is to close the search window - which then has to be reopened to continue/repeat the search.
This only happens if the search result is 1 row 'out of sight', and the behaviour is not new to the beta but also present in 2024.
Re: Search result bug...
Thank you for reporting this problem. I have forwarded the details further.
Return to “BETA: PlanMaker NX and 2026 for Windows”
