Classic Menus and Toolbar UI Options...Color?
Hook
Post by Hook »
I'm pretty sure I raised this suggestion during the 2024 beta, and I admit it is a fairly trivial feature request, but I'm also not quite sure why it would be difficult to do.
I use the classic menus and toolbars UI, not the ribbon UI. For some reason you give the ribbon UI a third interface option you don't give to the CM&TB UI... a color theme where each app is given a color trim the same color as the app icon. I really like having those colors, but have no interest in using a ribbon UI. Why aren't these colors also available for the classic Menus and Toolbar UI?
I would really appreciate it if this could happen.
Re: Classic Menus and Toolbar UI Options...Color?
I second this. Those of us who prefer the classic menu interface should not be relegated to second class user status.
Thank you for your post. I have forwarded this improvement suggestion.
Hook
Post by Hook »
Just being a pest and noting we still don't have this. ;-) I understand it is low priority, but then it is likely to slip through the cracks, so I'll keep being a pest, Lol.
It can't be that hard,,,
Not a pest at all ;-)
I've flagged it again to keep it visible. Still open and forwarded; just no implementation commitment or ETA I can give you yet because there are lots of factors involved in any feature implementation.
Return to “BETA: TextMaker NX and 2026 for Windows”
