Keyboard Shortcuts
adrianolira
Keyboard Shortcuts
Post by adrianolira »
I would like to suggest adding the following keyboard shortcuts:
Alt + = → AutoSum
Ctrl + Shift + L → Apply/Toggle Filter
These shortcuts are widely used in spreadsheet applications and would greatly improve usability and productivity for users transitioning from other office suites.
Re: Keyboard Shortcuts
Thank you for your post. I have forwarded this improvement suggestion.
adrianolira
I would like to suggest adding one more keyboard shortcut:
**F4** → Repeat the last action
This shortcut is commonly used in spreadsheet applications to quickly repeat the most recent command, improving efficiency and workflow, especially during repetitive tasks.
At the moment, Ctrl+Shift+Y is used for repeat, while F4 handles toggling cell references in formulas (switching the $ signs on or off). Since a single shortcut can't be mapped to two different actions, I've passed this improvement suggestion.
Return to “BETA: PlanMaker NX and 2026 for Mac”
