Print form
SteffJay
Print form
Post by SteffJay »
How do i print the entire worksheet using landscape without missing cells on the right?
Re: Print form
From the Page Setup menu, go to the 'Options" tab.
At the bottom left, in the field for Scaling Mode, select "Specify number of pages in total." The field to the right of that will change from a scale factor to a number of pages. Set that to "1" and it will scale the print range to print on one page.
SteffJay
Re: Print form
Post by SteffJay »
Hello Woody44. Many thanks for the reply.
That worked a treat my friend.
Your a star !!!
SteffJay
Re: Print form double side error
Post by SteffJay »
I have another problem concerning both side print.
I have four(4) sheets in my plan maker in total.
The printer default setting is print both sides of the paper.
It prints side one, retracts it (as if to print side 2) but spits it out without printing any thing.
Sheet 2 and 3 are printed on one piece of paper as it should do.
Page 4 is printed on one sheet, as that is the last bit to print.
How do i print both sides of the paper (1&2) ??
Re: Print form
Open the Print dialog box and choose the appropriate option from the “Double-sided printing” dropdown list.
Return to “PlanMaker 2024 for Windows”
