Work without Internet
IgorS
Post by IgorS »
Is it possible to use Free Office on a computer without an Internet connection? Connection is impossible even during serial number registration.
Re: Work without Internet
No, that's not possible.
You need an internet connection to request and enter a key.
The only option is a portable installation. Install and activate SoftMaker FreeOffice on a PC with an internet connection. Then, perform a portable installation following the instructions at the bottom of this page: https://www.freeoffice.com/en/support/i ... on/windows
Next, connect the USB stick to the offline PC and use the portable version.
