Date Reliant On system Date Fromat
BrentThirsk
Post by BrentThirsk »
The problem with planmaker being reliant on the system date format makes portablity an issue.
To make this completely portable to other PCs, would it not be better to have this format in settings?
Re: Date Reliant On system Date Fromat
There is no such issue. The date in a date column is only displayed in the system date format. Internally, it is stored as a date offset from 1900-01-01.
The sole exception would be when converting strings that look like dates to internal dates using conversion functions. But that is rarely used, and Excel has the same problem.
Return to “PlanMaker 2024 for Windows”
