Installation on a PC without an internet connection
Post here topics for SoftMaker Office 2024 for Windows that do not fit in any of the application-specific subforums.
TECHNO
Post by TECHNO »
Hi
I want to install FreeOffice 2024 on a factory PC.
However, the factory PC cannot connect to the internet.
I requested a product key from your company from my PC and received a reply email.
When I try to activate FreeOffice on the factory PC by entering the product key,
it asks for a connection to the server.
Is there another activation method that does not require the PC to be connected to the internet?
Best regards,
TECHNO.
Re: Installation on a PC without an internet connection
Thank you for asking.
You need to connect once to the internet for activating the software.
Else, you can use portable FreeOffice, for more details please follow this link.
TECHNO
Post by TECHNO »
HI
Thank you for your reply.
What are the differences in features and limitations
between the portable version of FreeOffice and the regular version of FreeOffice?
Best regards,
TECHNO.
It's the same FreeOffice. However, the version installed on your computer's hard drive requires an internet connection for activation, while the version installed on a USB drive can be activated from any other computer that has internet access.
TECHNO
Post by TECHNO »
HI
I immediately created a portable version on a USB flash drive.
I inserted the USB drive into a PC without an internet connection.
When I launched PlanMaker.exe from the USB drive, a dialog box requesting a product code appeared.
I entered the product code I had already received via email, but a dialog box appeared stating that it could not connect to the server.
Am I doing something wrong?
Could you please tell me the correct procedure?
Thank you.
Best regards,
TECHNO.
Post by Jossi »
SuperTech wrote: “can be activated from any other computer that has internet access.” So you have to insert the USB stick once into a PC *with* an internet connection to activate the program.
sjgarth
Post by sjgarth »
Going off at a bit of a tangent, does the factory PC have WIFI capability? If so, do you have permission to use a mobile phone to create a 'hot spot' to connect the PC to the internet temporarily just to get the package registered and activated?
Yours
Steve Garth
Noob at SoftMaker, expert at MS Office.
Return to “SoftMaker Office 2024 for Windows (General)”
