The app crashes once you put 3,000 OTF files within this app
StellarSans
Post by StellarSans »
When you import 3000 OTF files into SoftMaker TextMaker NX Android, the app crashes. Those files are a total of approx 800 mb. So what should I do because i have a lot of custom fonts? What other documents apps are there?
Re: The app crashes once you put 3,000 OTF files within this app
That's an unusually large font library for a mobile app. Most Android document editors aren't designed to handle 3,000+ OTF files at once.
A practical workaround: keep your master collection in cloud storage or an external drive, and only sync the fonts you actively need for current projects. You could also try a dedicated font manager to load fonts dynamically.
Return to “TextMaker NX for Android”
