very slow "copy" operation
vic
Post by vic »
Standard "copy" of a cell, after a "paste", takes about 4-5 seconds.
In a document with 2 sheets with about 117000 cells in total
Re: very slow "copy" operation in a big document
Please share your problematic file so we can investigate further.
If your file is confidential, please send it to forum[at]softmaker.com with a link to this post.
vic
Post by vic »
I have attached it.
To reproduce: go to the 2nd sheet, "test" and try copy a cell then paste. The "copy" op itself takes very long; while the "paste" op is fast.
Inside the 1nd sheet "large", not the "copy" but the "paste" operation takes very long.
EDIT:
I noticed that grouping (outlining) rows/columns affects the behavior in the "large" sheet: when the groups are collapsed, it's as described above; but when uncollapsed - the "copy" op is very slow, but the "paste" is much faster.
theFileWithSlowCopyOperation.xlsx
(3.07 MiB) Downloaded 235 times
vic
Post by vic »
I just tested the same file in the most recent, trial version of Microsoft 365's Excel, and there are no such delays there, and regardless of outlining status.
We were able to reproduce the issue at our end and have forwarded the details for further investigation.
Your file contains a very large number of formulas, which is causing the slowness — this behavior is typical under such circumstances.
To avoid this slowness while working, please go to the ribbon command Formula > Update group > Recalculate dropdown, and uncheck "Recalc automatically".
This will make your sheet faster, but calculations will no longer happen in real time. You can press F9 to recalculate manually whenever needed.
vic
Post by vic »
But have you noticed this:
"I noticed that grouping (outlining) rows/columns affects the behavior in the "large" sheet: when the groups are collapsed, it's as described above; but when uncollapsed - the "copy" op is very slow, but the "paste" is much faster."
vic
Post by vic »
@SuperTech, is it true in general that the Ribbon interface has more functions than the Classic one? I could not find a way to disable the auto recalculations in the Classic one.
This is about the user's preference regarding the interface. The ribbon interface is more widely used. In the commercial edition, you can add commands as needed.
To disable auto‑calculation in the menu interface, please go to File > Properties > Calculate tab and change the recalculation option.
vic
Post by vic »
thanks
I never thought of looking into File for settings.
Return to “FreeOffice PlanMaker 2024 for Windows”
