Sometimes TextMaker behaves abnormally
xeroname
Post by xeroname »
Hello.
While I'm using softmaker office 2024, I've found some odd behaviour after launch the TextMaker.
I've purchased license of SoftMaker Office 2024 Professional, and I'm using it on Windows 10 Pro.
- Sometimes the textmaker tries to bring its window to top.
When the problem triggers, I can't switch to other program's window for a moment, cuz textmaker trying to keep hovering its window continuously.
- It seems that launching textmaker increases wake-up time of OS-level sleep mode.
After I load textmaker document, go to windows -> sleep, and then when I trying to wake up my device, it takes too much time to get back my screen from black.
How can I solve these problems?
Thank you.
Re: Sometimes TextMaker behaves abnormally
Thank you for posting your problem. I have forwarded the details further.
Meanwhile, you can try the following workaround:
1. Please click on the ribbon command File | Options | Appearance tab.
2. Uncheck the option “Show tooltip”.
3. Press OK to confirm, and if required, restart the application.
