Unable to remove pages
Dennis N
Post by Dennis N »
I've produced a document consisting wholly of Header, Footer and the main document which consists of a table.
After reaching two pages in size I found that saving the document and re-opening gave me FOUR pages - the first two being duplicated as pages 3-4.
If I manualy remove pages 3-4, using 'delete table' or empty contents and then 'remove rows', and then save, close and re-open, then these errant pages re-appear!
Re: Unable to remove pages
We never heard this type of issue in the past. Kindly share the problematic file for our better understanding.
If your file is confidential, please email it to forum[at]softmaker.com and include a link to this post.
Dennis N
Post by Dennis N »
I can send you a copy by email if you give an address.
SuperTech wrote: Fri Mar 13, 2026 2:55 pm If your file is confidential, please email it to forum[at]softmaker.com and include a link to this post.
Dennis N
Post by Dennis N »
File sent - I hope.
Thank you for sharing the file.
We were able to reproduce the issue and have sent the file for further investigation.
Dennis N
Post by Dennis N »
Thanks for that.
After extending to a 3rd page, saving and re-opening the file has now expanded it to 10 pages!
I'm looking foreward to the explaination.
It appears there is some corruption in the file. To resolve this, please follow these steps (preferably both):
1. Right-click in the table > go to Properties > Table > Layout tab > change Wrapping from "Surrounding" to "None".
2. Save the file as DOCX (not DOC).
This should solve the problem and prevent the page from repeating.
Dennis N
Post by Dennis N »
Did that process - ended up with 19 pages !!
However, I created a new document, employed that "wrapping" setting you suggested and copy/pasted the first two pages.
This resulted in normal behaviour, so thanks for the efforts and I'm happy to call this problem closed.
Return to “FreeOffice TextMaker 2024 for Windows”
