License migration
Post here topics for SoftMaker Office 2024 for Windows that do not fit in any of the application-specific subforums.
License migration
I have a couple of desktop computers, several laptop, and a Microsoft Surface tablet, all running Windows 10. None of these devices qualifies to switch to Windows 11. Unless Microsoft changes their minds again, security updates will end in October of this year.
I have SoftMaker Office Professional on most of these devices, and on a couple I have either SoftMaker Officer 2021 or FreeOffice 2021.
I am seriously considering migrating all of these computers from Windows to Linux (probably LMDE6 or LMDE7). It is my understanding that the license for SoftMaker Office allows installation on five (5) devices, across all platforms. How do I migrate my licenses? Do I simply remove (uninstall) the software under Windows, then after changing the device to Linux I can reinstall SoftMaker Office using my same activation code? Even if I had previously used the activation code on multiple computers?
Thank you.
Re: License migration
Absolutely correct! 👍 You're a genius! 8)
That said, for the best experience and compatibility, we recommend using one of the pre-tested Linux distributions listed here.
Thank you.
I have decided to explore using LMDE (Linux Mint Debian Edition). The current version is LMDE7, but I have been advised that LMDE6 is better. I guess I'll have to look at both. It's pure Debian, so there should be no problem running the .deb version of SoftMaker Office ... right?
Debian is officially listed and supported. As for LMDE (Linux Mint Debian Edition), it's not explicitly mentioned, but since it's based on Debian, it may work well.
You're welcome to give it a try!
Return to “SoftMaker Office 2024 for Windows (General)”
