Pivot table included in XLSX gets fields switched in Planmaker 2024
Pedro
Post by Pedro »
Opening an XLSX which contains a Pivot table in a separate tab, opens in Planmaker 2024 but the fields are switched and the result is not the expected (in fact it has different results when opened under Windows and Linux Mint Debian Edition 7)
The file is this one
https://www.iccat.int/Data/t1nc_20260129.zip
The expected view is
while the result using Planmaker 2024 under Windows is
and the result using Planmaker 2024 under Linux is
It is really odd that the fields are modified when opening in Planmaker and also that the sort order is not the same under Windows and Linux
Maybe the developers can look into this for a future version?
Thanks!
Re: Pivot table included in XLSX gets fields switched in Planmaker 2024
Thank you for reporting this issue and for providing the problematic file.
I am able to reproduce the problem and have forwarded the details to our development team for further investigation.
Return to “FreeOffice PlanMaker 2024 for Windows”
