Slowdown with Beta7
lgsl
Slowdown with Beta7
Post by lgsl »
When working with documents that have 100+ comments TextMaker slows down considerable when you Add, Remove or edit comments. Once you do the first edit the slowness affects TM fully until you close the document. This issue can not be reproduced with TM2024 or LibreOffice so it rules out any document corruption. Disabling grammar checker does not help. Closing and opening the document once again works as a temporary fix. It affects docx, tdmx and odt.
This issue was not present in previous betas
Re: Slowdown with Beta7
Thank you for posting your concern.
This appears to be a file-specific issue, so we kindly request you to share the file for better understanding.
If the file is confidential, you may send it to forum[at]softmaker.com along with the link to this post.
lgsl
Post by lgsl »
Alas it is not a file-specific issue. I'll email you, anyway, a tdmx file with a partial copy of a document. This file was generated in TM2024. It works fine in 2024, but it does not on the current beta. This same document can be used to reproduce the other issue I reported with comment navigation.
Thank you for sharing the file. We were able to reproduce this issue and we have forwarded for further investigation.
Our developer team has fixed this issue for the next Beta update. Performance is improved now.
Return to “BETA: TextMaker NX and 2026 for Linux”
