Using FlexiPDF 2025 (registered), is it possible to exactly size a form field?
For example, I'd like to place text forms that are exactly 2.5 inches wide and 0.5 inches tall.
But when I go Insert/Form Field/Text box and right-click Properties, I don't see an option to resize or size the form field (or even check what size the form field is so I can do things manually).
Does anyone know if that's possible?
Is there a way to exactly size a form field?
Re: Is there a way to exactly size a form field?
The easiest way is to activate the grid (View > Grids and Guides > Snap to grid). Then you can draw a textbox form field with exactly the measures you need.
- ↳ TextMaker for Windows
- ↳ PlanMaker for Windows
- ↳ Presentations for Windows
- ↳ BasicMaker for Windows
- ↳ TextMaker for Mac
- ↳ PlanMaker for Mac
- ↳ Presentations for Mac
- ↳ TextMaker for Linux
- ↳ PlanMaker for Linux
- ↳ Presentations for Linux
