Print preview not copying standared view
oldrobcat
Post by oldrobcat »
This is about hiearchical numbered lists (again). Having got my level 1 and level 2 lists fudged to work, the print preview doesn't copy correctly. I found I could fix this by putting a "normal" blank line above the level-1 heading. The preview failed if a level-1 immediately followed a level-2 without a normal separating them.
Re: Print preview not copying standared view
Thank you for posting the issue.
Please share complete details of the problem with screenshot and the document in which you are facing this issue.
If your document contain confidential information then you can share at forum[at]softmaker.com with the link of this post for reference.
oldrobcat
Post by oldrobcat »
screenshots of standard and preview attached. The file is modified now to work, added an extra line
M05 _agreement_for_a_shorthold_assured_tenancy.tmd
(404.44 KiB) Downloaded 430 times
Thank you for sharing the document and screenshot.
We are unable to reproduce the issue with you file. The print preview in exactly same as per your file
Please check the screenshot of comparison for your reference:
