Drag tabs - suggestion
npferreira
Post by npferreira »
So, this is something that I would like to see, I dont know if its possible or not, but here it goes.
When you have multiple sheets on a file, it should be possible to drag the sheets to move them, instead of right click + move right, and this 10 times if I have 20 sheets and want to move it to the middle.
Re: Drag tabs - suggestion
Thank you for your post. Yes, you can drag a sheet's tab to reposition it.
Here is the correct method:
1. Click on the sheet tab with the left mouse button.
2. Hold it for a moment (less than a second).
3. Drag the sheet to its new position.
Please refer to the screen recording below for a visual guide:
nvk
Post by nvk »
Wouldn't it be possible to make it work like the document tabs do? You don't need to hold to reposition them. Just drag.
No, that is not possible in that way. The hold time is very short, only a brief pause. This signals to PlanMaker that the user wants to move it.
Return to “BETA: PlanMaker NX and 2026 for Linux”
